Pro 4xl seeing cameras on smart tv
  • 1 Reply
  • 896 Views
Ja1414
How can I see my cameras on my smart tv?
depending on the equipment you have,
I use a second gen firestick and alexa to view my cams on the tv.
you need to enable the alexa commands first.
How to add skills to Alexa using your mobile device
  1. Open the Alexa app on your iPhone or Android and tap the menu icon at the top-left. Open the top menu. ...
  2. Tap "Skills & Games" in the menu. Select “Skills & Games.” ...
  3. Tap the magnifying glass icon to search for the skill you want. ...
  4. Select the skill, then tap "ENABLE TO USE.
  • 1 Reply
  • 897 Views
