Pro 4
How do I uninstall the latest update, absolutely hate the format. I am currently stuck in standby mode and nothing is recording
You can't. The app supports both interfaces - which one you get is controlled by the Arlo Cloud. Arlo doesn't give you a setting to control which one you see. While you can migrate to Feed, it is not possible to migrate back to Library.
You are saying it is impossible for you to select the "Armed Home" or "Armed Away" mode? Normally you do that from the dashboard screen (the current mode is shown in color).
Arlo Pro 4
labels
Samsung SmartThings
