Have 3 cameras and can see the cameras and displays. Have a thumb drive plugged into hub. How do I record and playback on computer without a subscription. Using Arlo Web Portal.
I'm frustrated because was told didn't need a subscription. Got it to watch our amazing wildlife. Thanks!
Thank you everyone for your responses. I called the Costco Technical support. They gave me the Costco Arlo Tech line. We discovered that the Alro device needed to be plugged in directly to the Wifi Modem and not the ethernet cable connection that a computer can plug into in my office. Then the wonderful tech took us step by step thru the process of reloadings everything. When there was a problem, thru the support line we could send him photos of my screen. Now everything is working. My suggestion to Arlo -- I know you all don't work for Arlo -- is to get some good docmentation available for when someone opens the Arlo product box of the first time. It would have save us many hours of frustration. I was to the point of returning the birthday present I selected!
Now with the loaded USB correctly formated drive, we are seeing videos of all 3 cameras on my phone.
Thank you for helping me.
Thank you Arlo Costco support!
Have great evenings everyone!
Signed -- Wheaten
Please read the following,
Viewing locally recorded footage is limited to the app - it can't be done from the web browser. You can of course manually download them in the app (for instance to iCloud), and view them that way from a PC.
Also, there is no way to make manual local recordings (either from the app or the browser). Manual recordings are cloud only (so do require a subscription).
Hi StephenB (Guru),
I'm sending you the same information I just responded to DannyBear.
On the app on my Iphone 13 pro and my Dell Computer Windows 11, when I select Devices, I only see the 3 cameras. If one camera has 8 minutes before on it, when I open it, I ONLY see the present moment.
I can't believe spending over $300 I'm getting this. I followed the information on https://kb.arlo.com/000062337/What-is-Direct-Storage-Access-and-how-do-I-use-it-for-Arlo-video-recor... and here is my results:
StephenB,
According to box I just found that without plan the following are available:
Live Video Steaming - true
Local Storage -- * Requires USB port -- Doesn't work!
Motion & sound alerts - true
Also have no way to test out Alro Smart "after trail period." It doesn't even work on day 2 or 3 or 4.
Gizmo
StephenB and all following,
I decided my next option it to call Costco Concierge Services for help. At least I'll be able to talk to a live person there. Thanks for your help. If you find something I'm missing, please let me know.
Gizmo
No need to duplicate the reply, as the forum is all public.
Your friends with Pro 2 cameras are seeing cloud recordings. Legacy cameras had 7-day free cloud storage, which Arlo continues to provide. But Arlo stopped doing that with new camera models back in 2018 with the Ultra. With current cameras you need a subscription to get any cloud storage.
As I said above, there is no way to see local recordings on your Dell. Direct Access to local storage is only available in the app.
You appear to have the "Feed" user interface - seeing "Feed" as menu option on the main screen, and not "Library". With "Feed", if you want to see the recordings on your iPhone, the procedure is at the end of the article here:
- Tap Devices.
- Tap ... (upper right)
- Tap the settings wheel for your SmartHub.
- Tap Storage Settings.
There are limitations to this feature - IMO they result in a poor user experience.
- Local Recordings only available from the app (not the browser)
- Local Recordings only available from the primary account (not friend accounts)
- No ability to make manual recordings or snapshots.
- No thumbnails, so recordings need to be downloaded to the phone to view
- remote access requires router setting changes that some find difficult, and which won't work with some internet service providers.
Keep in mind that this is a user-to-user forum - neither @DannyBearAgain nor I work for Arlo.
StephenB,
Thank you for your help. I know you guys don't work for Arlo. I'm just very frustrated.
On my phone, in Devices, I tapped upper right ... Got the cameras. Taped on Camera C settings. It lists:
Device on
Battery
Connected to -- wifi listing
Power Management
Video Settings
Night Vision
Lighting Settings
Audio Settings
Default Mode Settings
Support
Pressed Default Mode Settings which list motion detection, audo detection, recording length - until activity stops or record for a fixed length, and Siren Sound Length.
I used to work technical support and that's why this is so frustrating for me. I guess I'll call Costco support for help unless someone has another idea.
Thanks for your help!
Gizmo
The instructions are to select the smarthub - not the camera.
Did you see the smarthub when you tapped the upper right ...?
Signed -- Wheaten
Arlo Pro 4
labels
Samsung SmartThings
