One of my 3 Pro 4s went offline today. I have removed the battery and deleted the camera from the app. Re-paired it and it keeps getting stuck at connecting. The other cameras are on-line and so its not the app or my wifi connections.
Have you tried the reset procedure?
https://kb.arlo.com/000062438/How-do-I-factory-reset-and-re-sync-my-Arlo-camera
Arlo Pro 4
labels
Samsung SmartThings
