Pro 4 - scan the barcode then it says can’t find device
  • 4 Replies
  • 1177 Views
Rustytina
Pro 4. I got 3 cameras at best buy 3/1/22. Now. Only 1 camera will sync I how tried all the reset stuff and stop can’t get the other 2to sync. Both of them does scan the barcode then it says can’t find device
Rustytina,
Are you resetting the cameras using these instructions: https://kb.arlo.com/000062438/How-do-I-factory-reset-my-Arlo-wire-free-camera
Rustytina
I done the reset again today 10 times each. No luck. I am ready to send them back for a refund.
Rustytina,
Try charging the cameras before going through the onboarding process. What LED behaviors do you see on the cameras when attempting to sync?
Rustytina
I go back to add camera then go through all the steps to set it up The camera led brinking blue scan barcode. I hear chime then it starts looking for the camera. Can’t find device. I then hold down the reset button till the 3 amber light. It starts blinking blue rescan barcode. I hear chime. Then it starts looking for device. Not found.
  • 4 Replies
  • 1178 Views
