Pro 4 not picking up motion, battery issues, etc.
  • 1 Reply
  • 1368 Views
desertrat1981
  • My pro 4 is on CVR.  Even while plugged in, the battery would last around 24 hours.  Replaced with another battery, same thing.  I couldn't view live, but it would pick up motion.  So I removed the camera, then reconnected.  Now the battery last maybe 48 hours, and now no motion  detection.  I can view live though, but no good without motion  detection.
  • Any ideas?
I am thinking the charger isn't supplying enough power.  Do you have another one you can test with?
CVR should work with AC power even if you remove the battery altogether.
  • 1 Reply
  • 1369 Views
