2 issues:
1. I have turned off my pro 4 camera but it stills records when it activated by movement. How do i fix this?
2. The volume coming from the camera is really quiet when someone is talking but the siren is loud. How do also fix this?
Cheers
Regards the camera on/off status, are you using the website login to switch the camera or a mobile device app?
Regards the audio, again which app is being used?
Arlo Pro 4
labels
Samsung SmartThings
