Pro 4 do not see QR code anywhere
  • 7 Replies
  • 3130 Views
King41
New camera, do not see QR code anywhere
7 REPLIES 7
My recollection is that there is no printed QR code for the Pro 4.
Are you seeing a prompt to scan one when you on-board?
King41
Yes it prompts you to scan QR and will not go any further
Are you sure you are selecting the correct camera model when you "Add device"?
King41
Positive that I selected the correct model, I have checked and rechecked it.
So frustrated, zero customer support.
I started the "add device" process selecting the Pro 4, and did not see any prompt to scan a QR code from the app. So I am puzzled that you are seeing this.
If you are onboarding to your home wifi, the app will generate a QR code for the camera to scan, after you enter your WiFi credentials in the app.  But you shouldn't be seeing a step where the phone camera needs to scan a QR code.
What version of the app are you using?  Also, is this Android or iOS?
Have you also tried onboarding using a PC (browse to my.arlo.com).
King41
Ok so I am a idiot, I thought the QR code was on the camera and you needed to scan with your phone.  Not the big QR code that shows up on the app and then you scan with the camera.
Now if will not find wifi, I have starlink that has both 2.4 and 5.  It will not find it.  Went in and separated the wifi into two separate wifi's and while using the 2.4 the camera will not connect.
Is the phone also connected to the 2.4 band?
Is the network security set to WPA2 (AES)?
Assuming yes to both:
  1. Sometimes onboarding works with a PC (browsing to my.arlo.com) when it fails with the app.  So you could try that.
  2. There are some characters that won't work in the network password (and perhaps the network name).  Unfortunately Arlo hasn't told us what they are.  But if you do have punctuation, you could try removing it (or just substituting a different symbol).
  • 7 Replies
  • 3130 Views
