Pro 4 camera compatibility
Hi
I have a set of Pro 4 cameras and am looking to add additional cameras to my setup.
are there other models which would be compatible or do I need to stick with pro 4?
thanks
@Slats wrote:I have a set of Pro 4 cameras and am looking to add additional cameras to my setup.
Any of the cameras are compatible, though a couple models would require that you get a smarthub, since they don't connect to your home wifi.
Some of the newer ones might not be available in your geography - you can check for that by going into "add device", and then make sure the camera you are interested is listed there.
Arlo Pro 4
labels
Samsung SmartThings
