Pro 4 camera charging transformer comparability
Just purchased several Pro 4 cameras, but they only came with one cable and power adapter. I have several Pro 2 transformers and want to know if they are compatible with the Pro 4 camera. If so, I only need to buy a magnetic cable, not a cable with adapter attached.
I also noticed the transformer adapter with the usb connection is not listed on the Arlo site as an accessory option.
Anyone know?
@Just1Guy wrote:I also noticed the transformer adapter with the usb connection is not listed on the Arlo site as an accessory option.
The photos are misleading. If you look at "what's included", you will see that there is a power adapter.
Arlo Pro 4
labels
Samsung SmartThings
