I have 4 arlo pro cameras, 1 arlo pro 2, 3 arlo pro 4, and a wifi video doorbell. I also just signed up for Arlo Secure. I setup the smart notifications for each camera I have.
Notifications on my Samsung S8 running Android 9 are now messed up.
If I get, for example, and animal detected alert, the notification will at first show a screen shot of the video and have the green box around the animal. Works good, but after about 1 minute that notification turns into an Animated Preview and starts playing. When it does this the notification background turns white and the text turns white and I can't see any of the info about the notification.
I went into the smart notification settings for each camera and turned off Animated Preview, rebooted the arlo base and rebooted my phone, but I still get the Animated Preview notifications.
How do I turn off the Animated Preview notifications?
It appears that this issue has been fixed by Arlo. I've made no changes to my phone or the arlo app but today notifications are working correctly. I am no longer getting animated previews, which is how I want it, and the background colors and text colors are correct as well. I now only get the notification with a thumbnail and the green box drawn around the object that cause the alert.
So either this was a known issue and arlo fixed it.
Or arlo saw my posts, saw it was an issue and fixed it.
Or maybe it took 3 days for the arlo secure settings to propagate to all the arlo data centers & servers.
Either way, it's working now, and I like it.
Here is what the notifications look like. The grey ones are when they first come in. If you expand them you see a thumbnail and a green box around the object that created the alert. Works fine.
The white ones are what they grey ones turn into automatically after about 1 minute. If I expand them, you see the animated preview.
I don't want to animated previews and have turned them off in settings, but I still get them.
How do I stop the animated previews? If this can't be fixed I'll have to return the $550 worth of equipment I just bought from Arlo.
Arlo Pro 4
labels
Samsung SmartThings
