Pro 4 - Google Fiber cannot split the 2.4 and 5g network.
We recently switched to Google Fiber and it doesn't let you split the 2.4 and 5g network. Google says the device should automatically find the 2.4 but it isn't. How do I get my Arlo Pro 4 to connect to the wifi if I can't split the 2.4 from the 5g?
Using a computer to go to the web client (my.arlo.com) should help.
Can you be more specific? How will that help? What should I do there?
Arlo Pro 4
labels
Samsung SmartThings
