Pro 4 Camera charging port protective cover.
I just purchased a PRO 4 Camera for use outside and there is no cover over the Battery charging port. Is there supposed to be one. With out it, it will be subject to get rain and moisture on it.
@Makc56 wrote:
I just purchased a PRO 4 Camera for use outside and there is no cover over the Battery charging port. Is there supposed to be one?
No (this is also the case with the Ultra and Pro 3 cameras).
Mine have been outside for a few years now, and I have had no issues with moisture.
The idea is that having the port on the bottom along with the spacing of the connections doesn't require a cover or weathersealing.
Arlo Pro 4
labels
Samsung SmartThings
