Pro 4 2 step verification has stopped sending sms codes to my mobile phone. "Either number is not va
"Either number is not valid or region is not supported." why am I getting this notice as my mobile number has worked perfectly up till now. the 2 step verification will only use my email to get code.
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
Arlo Pro 4
labels
Samsung SmartThings
