I have 3 pro 4's, bought as a new set 7/15/2023. All are set to optimzed power, but one kills batteries.
Swapped batteries and even moved camera, still kills battery in a week or two while the others show near full charge.
Camera issue?
Camera issue?
Are you saying that when you swap the camera with one of the others, the problem moves with the camera?
Is the motion threshold the same for this camera as it is for the others?
no, I swapped batteries to take a bad battery out of the equation. All the cameras settings are at the defaults.
Understood. But did you also swap the camera, to take the location out of the equation?
Arlo Pro 4
labels
Samsung SmartThings
