No more iOS notification from Arlos app
Hi all,
Ever since updating to iOS 26.5.x, Arlo notifications have stopped working for me. Is anyone else experiencing the same issue?I've already tried toggling notifications on and off, but that didn't help. Normally, iOS should prompt you to allow notifications when enabling them in the Settings app, but I'm not seeing that prompt either. Has anyone found a fix or workaround?
Can you please try to uninstall and reinstall the app?
Arlo Pro 4
labels
Samsung SmartThings
