Multiple armed areas
  • 4 Replies
  • 1236 Views
Roller66
Can you arm cameras separately?
Options here depend on the details:
  1. whether you see "Library" in the app menu, or whether you instead see "Dashboard" and "Feed"
  2. whether the cameras are connected directly to your home wifi or whether they are connected to an Arlo hub.
Roller66
2 are connected directly to the wifi and 3 are on a hub.
Roller66
The app has feed not library.
The three modes control all the cameras at a location.  You can modify all three modes, but cannot add more. So you can create three combinations of cameras.  For instance
  • Arm Away can arm them all
  • Arm Home can arm a subset
  • Standby can arm a different subset
If you re-purpose Standby, then of course you don't have an easy way to disarm all the cameras.  But you can turn off cameras in the video settings, which of course will also disarm them until you turn them back on.
This is an area where "Feed" needs to be improved, hopefully Arlo will do that soon.
  • 4 Replies
  • 1236 Views
