Lost security key on the back of camera mount in order to open battery or recharge
I lost security key on the back of the camera in order to open the battery or recharged
I don't have a security mount so can't give details but check your local hardware store for a set of small "jeweler's" screwdrivers. They should come in a variety of sizes as well as straight-slot and Phillips. Use the largest screwdriver that fits properly to avoid damaging the screw head.
Arlo Pro 4
labels
Samsung SmartThings
