Just bought Arlo 4 VMC4350p Chimes, but Won't Connect to Wifi
  • 6 Replies
  • 1859 Views
klockestx123
Hi I recently purchased the Arlo Pro 4 (VMC4350p) that came with 3months of Arlo Secure. I have gone through the setup process with my first camera and I get it to chime with the QR code step on my app but then in the next step there is no camera found. I have tried many times and also gone through all the troubleshooting steps. I would like to contact Arlo Support over the phone to troubleshoot which should be included with Arlo Secure (and because I just recently purchased 3 cameras) but there doesnt seem to be a way to call anyone. Please advise.
klockestx123
Thank you Stephen B - i deleted the app and re-installed the software and it was able to find the camera. Thanks again for your assistance!
6 REPLIES 6
ShayneS
Hey klockestx123
Are you still experiencing this issue setting up your cameras?
klockestx123
Yes- unfortunately. Any thoughts or anyone I can speak to on this? I think that if I'm unable to get to to work I am going to return the purchase. Thanks
Interesting that at this moment your response is message 3 of 2.
ANyways, can you get any camera to connect? That will allow you to use Settings, Support to get a phone number, etc. to use. Without a camera connected, you can't contact support.
Things to try:
- Disable the 5GHz band on your router if possible. Otherwise, try to ensure you're on the 2.4GHz band with your phone.
- Use a computer to attempt installation.
klockestx123
Thanks unfortunately that didnt work either.  (And dont have any cameras installed on the app so cant reach support!).
@JamesC might be able to help with that.
klockestx123
  • 6 Replies
  • 1860 Views
