- I was about add a pro4 to my install base of essentials but then noticed that it uses a magnetic mount. That seems really suspect for a security camera because a well aimed baseball could knock it out of the base right ? Does the camera come with both mounts ?
Typically, no. Some systems come with both types of mounts or you can buy an accessory mount. Many time the magnetic mount is fine but that depends on your environment and level of paranoia.
Arlo Pro 4
labels
Samsung SmartThings
