I need to feed the outdoor USB cable through a wall
I need to feed the outdoor USB cable through a wall. If you used a USB Type-C connector in place of the Type-A then I would only need to drill a 10mm hole rather than a massive 15mm one!
Was using a solar panel not a suitable alternative?
I agree that it would have been better if they made a cable that was designed to be pullable. IMO opinion an in-line connector would be better than switching to USB-C, as it could be about the same thickess as the cable itself.
If you are prepared to risk the charger you could cut the cable, pull it, and then splice it.
Arlo Pro 4
labels
Samsung SmartThings
