I have 2 Arlo Pro 4 cameras and they will not connect to my Arlo App. I have reset them also
  • 5 Replies
  • 610 Views
crash40burn9
I have 2 Arlo Pro 4 cameras and they will not connect to my Arlo App. I have reset them also. I have 1 other Arlo Pro 4 camera along with 2x Floodlight cameras and 4x Pro 5S 2K cameras that connect no issue. I have also noticed that there is a micro USB connection on the side of the Arlo Pro 4 cameras when not in their case, what are those used for? And how can i get my 2 Pro 4 cameras to connect?
5 REPLIES 5
Try a reset on those cameras:
https://kb.arlo.com/000062880/How-do-I-factory-reset-and-re-sync-my-Arlo-camera-Arlo-Secure-4-0
I suspect the USB port is for factory use only.
Queenie27
I can not get my Arlo Pro 4 to reconnect after a factory reset.  It keeps saying it can't find it.  I've tried 3 times. Help!
Did you also remove the camera from your account before trying to add it again? You can't add a device that's already in your account, even with resetting.
https://kb.arlo.com/000062438/How-do-I-factory-reset-and-re-sync-my-Arlo-camera
crash40burn9
I have done all that and it never seems to find them. They have never been added to my app, so this is the first time trying to connect
We need all details. What have you tried - exactly - and what do you see?
  • 5 Replies
  • 611 Views
