I cant open the "time zone option" on my hub! any ideas?
Eric1996,
I'm not able to reproduce an issue with time zone. Which app are you using (iOS or Android). Wat happens when you try to adjust the time zone?
I can’t change my time zone either. Using iOS, has my address in the app, but is showing a time zone 3 hours earlier than where the cameras are. The time zone is not selectable in the app (grayed out).
Try rebooting your phone and reinstalling the app. Have you tried removing a camera battery and reinserting it to see if that helps?
Software up to date, however I have the same problem and they sent a screenshot to corporate. No response yet. Have had a horrible time with Arlo. Support is not in the USA and it is difficult to understand them. Also, not too helpful. First guy said both cameras from my 3 pack were defective and I should return them to Best Buy. Second guy requested the screenshot for further review.
A nightmare trying to work with them. Bought the three pack 4 days ago and tried to cancel my first account and create a new one thinking it would solve the issues….Not.
Now I have the following issues.
-Time zone won’t change
-Constant static sound
-Manual does not match App menu
-No longer have the trial subscription when I changed email accounts
-Can’t change back to my original email account.
Probably more issues to come. Did they launch the Pro4 too early before testing it out. So frustrating!!!!
Arlo Pro 4
labels
Samsung SmartThings
