I can’t get my cameras to work in my barn with point to point WiFi
  • 1 Reply
  • 664 Views
Icono
I can’t get my cameras to work in my barn with point to point WiFi signal with client and repeater installed? What can I do to make them work?
Are these Pro 4s?  (you chose VMC4030 in the model field, which is the older Pro).  Are you wanting to connect them directly to the WiFi (and not a base station in the barn).?
  1. What model of repeater/extender did you use?
  2. Have you tested that you can reach the internet from your phone when connected to it's wifi (and with your cellular data turned off)?
  3. Is the network secured with WPA2 (AES)?
  • 1 Reply
  • 665 Views
