How do I connect my Arlo pro 4 to a network that requires ssid and user name plus password?
  • 1 Reply
  • 1181 Views
PictorGuy
I have a new Meraki network that requires that I enter a login ID and password after joining the SSID?  How do I join my camera to this new network ?
You can't.
What you can do is get a compatible base, and connect the camera through that base.  Note the base connects with ethernet, and I am assuming that your network won't require entering a login ID/password for ethernet connections.  https://kb.arlo.com/000062284/Arlo-SmartHub-and-Base-Station-Compatibility
Alternatively, set up a second wifi network that doesn't have this restriction.
You can't.
  • 1 Reply
  • 1182 Views
