I have a new Meraki network that requires that I enter a login ID and password after joining the SSID? How do I join my camera to this new network ?
You can't.
What you can do is get a compatible base, and connect the camera through that base. Note the base connects with ethernet, and I am assuming that your network won't require entering a login ID/password for ethernet connections. https://kb.arlo.com/000062284/Arlo-SmartHub-and-Base-Station-Compatibility
Alternatively, set up a second wifi network that doesn't have this restriction.
You can't.
Arlo Pro 4
labels
Samsung SmartThings
