  • 1 Reply
  • 1514 Views
Exit99
I just ordered the Pro 4 (VMC4350B-100NAS) which came with 3 wireless cameras and 1 wireless video doorbell. Do I need a SmartHub? If so, which one is compatible? I do not see the Pro 4 listed under the compatibility lists.
No, you don't need a hub unless you want local recordings. Any base or hub starting with the 4500 is compatible with the Pro 4:
https://kb.arlo.com/000062284/What-is-the-difference-between-each-Arlo-SmartHub-and-base-station
  • 1 Reply
  • 1515 Views
