My camera has this halo. Mostly noticed when it’s getting dark and at night. Any ideas how to fix it?
Looks like a bit of Ir reflection off the house…
easy test is if you aim it straight out at night, does it do the same?
Prob answer is to angle slightly more away or a mount that holds it out a bit more…
magnetic mount now used?
Arlo Pro 4
labels
Samsung SmartThings
