General Information
  • 1 Reply
  • 1030 Views
SJM99
I am looking into buying (2) exterior camera, thinking about Pro 4 with a smart hub. Will the smart hub save any picture on the hub that I might need to save. I'm not interested in buying a security system.
Also, not sure if the 5 camera is better?
Sam
The smarthub does support the direct access to local storage.  You'd need to put add a flash drive (at least 16 GB) to the system.
While some people here do use this feature instead of a subscription, IMO it isn't a very good user experience.
  • Recordings can only be viewed in the app - not the web browser
  • Recordings can only be viewed from the primary account - not shared "friend" accounts
  • No ability to take snapshots or make manual recordings
  • No thumbnails - videos need to be downloaded to the phone to view.
  • Remote access requires router setting changes that many find difficult (and which don't work with some internet service providers).
There are some other features that you lose without a subscription:
  • activity zones (unless the Pro 4 is connected to AC power)
  • smart notifications.
  • 1 Reply
  • 1031 Views
