Does the arlo pro 4 xl offer continuous recording? Is it possible without a subscription? I have a 3 camera system with a hub. Just curious if it does. I understand I would probably need to have the camera continuously charging. Thanks in advance
Yes, if the camera is AC powered. (Solar power won't do it).
No. CVR has it's own subscription (different from Arlo Secure).
So to clarify, if it's powered by ac it has the cvp recording? But not without a subscription? I think the cvp subscription is crap not only expensive but unable to download to a usb drive!
@Cornish_man wrote:
So to clarify, if it's powered by ac it has the cvr recording? But not without a subscription?
Correct. You need both AC power and the CVR subscription.
Arlo Pro 4
labels
Samsung SmartThings
