  • 1 Reply
  • 896 Views
Colin1234
Recently updated the app and now I can't disarm one of the cameras. If I am working in the backyard and still want my front camera operating I can only disarm all or turn them off which doesn't allow me to access the camera at all.
Unfortunately the new app is limited in control of individual cameras (or groups of cameras).  I suspect Arlo is working to fix that.
If you aren't using both Arm Home and Arm Away, you can modify Arm Home to disable the backyard cameras, and just switch to that.  Of course that is just a partial solution, since you disarm just the front cameras that way.
  • 1 Reply
  • 897 Views
