Has anyone had as much trouble as I have with customer service/support? The support people do not seem to know much about the product. One gave some kind of dismissive response like, take them back to where you bought them. I have to send pictures of their camera to them for them to see how it is designed. I've responded to their emails and sometimes they refer to previous correspondence and sometimes it seems like they don't know anything about previous contacts. Also, I have typed my issue into their system and it wipes it out and says their server isn't working. Be sure to copy your message before you submit to avoid doing it over again. I can't remember having to work this hard and getting nowhere. It's been 3 days and they have been zero help. I guess I will have to return the cameras for another brand before my return period ends ( as they suggested)
Rcwake,
Do you have a support ticket number I can refer to and escalate as need?
I have returned the cameras so you can close the case.
Arlo Pro 4
labels
Samsung SmartThings
