I have got Arlo Pro 4 camera, and I have downloaded the Arlo apps via Android, it shows the error message when I create an account. I have tried several times, and it still has the same problem. Also, there is not option for me to create an arlo account through website. How to solve it? Thank you.
What error message are you getting?
Are you using my.arlo.com? You should be seeing this:
Problem solved. I can login by this community account. No need to create a new account via mobile app.
Thanks.
Thanks.
Arlo Pro 4
labels
Samsung SmartThings
