  • 1 Reply
  • 561 Views
Victor5
OK, the documentation says that I can connect a USB device to my Smart Hub.  I cannot find a port.
I am on a network with a NAS.  Can I direct a stream through the network to the NAS?
What model hub do you own?  Look for a VMBxxxx label on the base.
If you have a VMB5000, then it has no USB port, but instead has a microSD slot in the base.
No, Arlo doesn't support that feature.
  • 1 Reply
  • 562 Views
