The instructions say that to connect to an Echo Show, the Arlo should be connected to the cloud. Is that a requirement, can I connect to my Echo Show using only WiFi and no cloud?
@Eltee wrote:
I was hoping that I could keep the system cloud free
That is not possible with Arlo - it is designed as a cloud service. But there are services that don't require a subscription.
https://kb.arlo.com/000062312/What-options-will-I-have-when-the-Arlo-Smart-3-month-trial-plan-ends
Are you asking if you need a paid subscription?
The Pro4 is always connected to the Arlo Cloud (either through your base or through your home wifi).
Yes, I think so. I would like to avoid paying for the subscription services if possible. I am new at this and didn't quite understand that there could be free cloud service?
I was hoping that I could keep the system cloud free and leave it as a simple pair of Pro 4 cameras connected to my phone / computer via wifi only.
Sorry, I am a total newbie.
Arlo Pro 4
labels
Samsung SmartThings
