The Time Zone associated with a location is grayed out and the setting do not let you change the original setup. Has anyone figured out how to do it without deleting the location and starting over?
You can change the address, and the time zone will automatically switch to the time for that location.
Unfortunately, the only way to set the time zone itself it is delete the location, create a new one, and then be careful not to enter the address for the location.
Arlo Pro 4
labels
Samsung SmartThings
