  • 5 Replies
  • 1412 Views
CB8709
Unable to change modes and modes does not follow the rules. Is there any other with same problem? Cant activate or deactivet the cameras (same on iPhone and computer)
5 REPLIES 5
CB8709
It seems I can control them one by one but not enable all as well as close them under the mode button and select all at once....
Do you see "Library" in your app menu?
Or do you instead see "Feed" and "Dashboard"?
Are the cameras connected to an Arlo Hub?
Or are they connected to your home wifi?
CB8709
Yes, "library" is the one between "units" and "location"
All the cameras are on wifi with full connection. I can start them also!
With "Library", cameras connected with your home wifi are armed/disarmed independently from the modes page. You should be seeing each camera listed there, with the option to arm and disarm each.
Is that what you are seeing?
CB8709
I have the app in Swedish, but only recorded videos are in the library. It's the tab to the right of it called "mode" where I can select which camera I want or select all at once.
Seems to have solved the problem though, it seems. One of my cameras had a low battery note. I unplug it and charge it up. When I just started it up it the system seems to work normally again.
However, very strange that this happened when some cameras were activated and others were not....
  • 5 Replies
  • 1413 Views
