I recently made a wifi switch and discovered I am unable to change the wifi my cameras are connected too. I followed what the online article told me to do but I don’t have the option to change wifi. With the school year coming up I am in dire need of my cameras send advice!!
The simplest thing to try setting up the new wifi to use the same network name and password as the old one.
The other option is to remove them from your account, and then do a hardware reset of the cameras. Do that by removing them from the housing and pressing the sync button inside until the camera LED flashes amber (~15 seconds). Then add the cameras back to your account.
Arlo Pro 4
labels
Samsung SmartThings
