Cannot connect camera to smart hub
  • 17 Replies
  • 4089 Views
Petag1962
Hi
i recently closed my Arlo account and now I can’t connect my cameras to the base station. Surely you don’t have to pay to connect them. Thoughts anyone?
17 REPLIES 17
Do you mean you just canceled your subscription?  Or did you also delete your Arlo account and then created a new one???
What model base station do you own?
Also, can you confirm that these are Pro 4 cameras?
Petag1962
Hi Stephen
i let my subscription expire as I thought that the information would still be stored on the hub USB, guess I was wrong there
I have 3 pro 4 cameras and 1 pro 5 which was a replacement when one of the pro 4’s died
My base station is a VMB4540 which is connected to my Wi-Fi. The cameras all work and show an occurrence but won’t zoom or leave the occurrence on my phone
if they cannot be connected to the base station the whole set up will Bo on market place by day’s end
thanks
Chris
DannyBearAgain
You will need a multi camera subscription to be able to get the recordings from the arlo cloud storage.
The base’s backup USB should have the recordings but you need to use the arlo mobile app to download them to your mobile to view them. You will need to remove the USB to view recordings earlier than a month on a pc.
If you had a USB drive connected to the hub, then they should have been.  Assuming that local storage was properly set up in the app.
Eject the storage and check it on a PC.  That will help us figure out if you have a recording problem or a playback problem.
Petag1962
Hi, thanks for replying
The USB I am using is fine as I can store a document on it, no problems. I just removed it from the base station and received an error message that it wasn't removed correctly, so the base station recognises that the is one fitted
All I need is the cameras connected to the base station and any incidents recorded on thecvUSB, I don't need or want cloud storage
Thanks again
Chris
You do need to first eject the USB drive using the app - the smarthub is not as forgiving as Windows on that.
Do you see your recordings on the drive when you attach it to a PC?  Sometimes the problem is a recording problem, sometimes it is a playback problem.  It's helpful to figure out which.
I am confused on what you mean here.
Are you saying that your cameras are connected to your home wifi, and not connected to the smarthub wifi?  Or are you just saying that local storage isn't working for you?
If you aren't sure how the cameras are connected, then just turn the smarthub off, and see if the cameras all go offline.
Petag1962
Hi
As stated, i cannot connect the cameras to the base station. The base station shows as being online and the cameras are working but connected to my wifi
when I try to connect my cameras to the base station, I receive the error message “cannot locate camera”. Why is this and how do I fix it?
thanks. Chris
Petag1962
Hi
I have had a look at the links but not very helpful. I have the very basic issue of my cameras won’t connect to my base station. The base station is online and my cameras are connected to my Wi-Fi. However they do very little that way so I want them connected to the base station. I have tried uninstalling everything but that doesn’t help. The base station searches for a while but can’t find the camera so I press the sync button as directed but still nothing. Is there someway I can upload a video of this happening?
thanks
Have you tried the reset procedure for the cameras and then attempt to connect them to the hub?
https://kb.arlo.com/000062880/How-do-I-factory-reset-and-re-sync-my-Arlo-camera-Arlo-Secure-4-0
DannyBearAgain
Petag1962
I have read and tried everything that has been suggested to me by this community without success. I have factory reset everything and reinstalled the whole system without any success. The cameras work but don’t record to USB nor do they track or zoom when they detect something. I now believe that without a subscription they are useless and that I am being held to ransom because I canceled my subscription. They are now going on market place and I will buy something less fussy doesn’t require a subscription
thanks anyway
Chris
What hub model do you have?
Do you see "Feed" and "Dashboard" in your app menu?  Or do you instead see "Library"?
Petag1962
My base station is model VMB4540. I can see feed and cardboard but not library
If you
  1. go to the devices page
  2. press the tile for the smarthub
  3. press "storage settings"
Do you see the local recordings there?
Also, double-check that the cameras are connected to the base (and not your home wifi).
Petag1962
Hi
I see dashboard and feed.
On the base station storage settings, I see "record locally" and when I go to local storage settings, I see that storage status bis good with plenty of available space.
The USB is actually lit up in the base station but it isn't recording
Is there anyway I can send a screen shot, it would be far easier
Also, while the cameras seem to be working okay, they are not zooming in or tracking. The light comes on and I do get a notification that it sees something
Thanks for your help with this, the answer i bound to be something simple
Chris
Yes,  Use the camera icon in toolbar above the posting textbox.  You can submit either png or jpg.
  • 17 Replies
  • 4089 Views
