Do you use a smarthub, or are the cameras connected to your home wifi?
Did you try the factory reset?
If you didn't try the reset (and don't use a smarthub), try setting the new modem's network name and network password to match the old ones. Make sure the security is set to WPA2 (AES). Then remove/reinsert the battery on one of the cameras, and see if it connects.
@Ethan18 wrote:
Now I’m trying to link the three cameras back up and it’s impossible. Thanks again
What exactly have you tried here?
@Ethan18 wrote:
What amazes me is I can’t get a person on the phone. I’ve been a customer for 5 years and this new Arlo 4 is only 6 months old and has given me more problems then the old in 5 years
If you have a subscription, then you should see a phone support option in the app.
Ethan18,
I see you mention a Sonos system above. These systems generally have very strong WiFi signals that can cause interference, resulting in the symptoms you're describing here. You might try disabling the Sonos system (temporarily of course) and then attempt onboarding your Arlo cameras to see if you still experience the same behavior. Additionally, be sure your mobile device is connect to the 2.4Ghz band and not the 5Ghz band on your network when going through onboarding.
Ethan18,
I see you already have a support ticket open on this issue. I will review your support ticket and request a status update.
Arlo Pro 4
labels
Samsung SmartThings
