Hi Folks
I’ve reviewed the forum and Googled but not found the definitive answer … can I set up Pro 4 cameras on a BT Smart Hub 2?
Thanks in advance
You should be able to (there's nothing in the router specs that suggest it won't work).
Hi LaSanta
That is my current setup and I had no issues whatsoever with connecting my Pro 4s to the BT Smart Hub 2
Thank you for taking the time reseaerch to respond ... genuinely appreciated
Arlo Pro 4
labels
Samsung SmartThings
