Can I set up Pro 4 cameras on a BT Smart Hub 2?
  • 1958 Views
LaSanta
Hi Folks
I’ve reviewed the forum and Googled but not found the definitive answer … can I set up Pro 4 cameras on a BT Smart Hub 2?
Thanks in advance
You should be able to (there's nothing in the router specs that suggest it won't work).
adinx
Hi LaSanta
That is my current setup and I had no issues whatsoever with connecting my Pro 4s to the BT Smart Hub 2
LaSanta
Thank you for taking the time reseaerch to respond ... genuinely appreciated
  • 1959 Views
