Camera working intermittently now?
  • 6 Replies
  • 2414 Views
lgbalfa
My porch camera seems to work only sometimes but not all the time.
For example, my wife picks up our daughter at the bus stop and I usually see them walk into the house around 4pm.
The porch camera always detects this but recently, a lot of times the camera does not detect it.
So basically, my porch camera only works intermittently now.
I checked for firm ware updates and there are none.
Any suggestions?
Maybe clean the exterior of the camera around the lense?
6 REPLIES 6
Are you using any activity zones? WHat is the motion sensitivity set to in your modes and rules?
lgbalfa
I am using activity zones.
I actually made it closer to hopefully capture the area better to see if that works
Where do I find the motion sensitivity?
https://kb.arlo.com/41/How-do-I-change-the-motion-sensitivity-on-my-Arlo-camera
The detection range is spec'd as "up to 25 feet".  From my experience, actual range depends on the details - how large the object is, temperature, whether the motion is towards the camera, or across the field of view, etc.
lgbalfa
Thanks.
I will adjust the that.
Do you think if that does not work, I should remove the camera and then re-install it from scratch?
That sometimes will resolve problems, so it would be worth a try.
lgbalfa
I increased the Activity Zone and the sensitivity.
So far it seems to be working much better.
Will keep you posted.
  • 6 Replies
  • 2415 Views
