Why is it so complicated to subscribe to the CVR plan? I followed every single step that the support team told me to do and i STILL cannot subscribe to the plan. Literally wasting time, money, and effort trying to set this up. Can't ever contact someone from support, and the phone number listed at the bottom of the "contact us" page isn't even a working number. You try to call 1.408.638.3750 and it say "the number you have dialed is not in service". Like, i'm about ready to return everything and go with a different security cam brand.
@j_relampagos wrote:Why is it so complicated to subscribe to the CVR plan? I followed every single step that the support team told me to do and i STILL cannot subscribe to the plan. Literally wasting time, money, and effort trying to set this up. Can't ever contact someone from support, and the phone number listed at the bottom of the "contact us" page isn't even a working number. You try to call 1.408.638.3750 and it say "the number you have dialed is not in service". Like, i'm about ready to return everything and go with a different security cam brand.
Is your Pro4 connected to a Hub/Base? CVR will only work connected to one, not your home wifi.
Have you tried on the web portal instead of the phone app?
You should try calling support again as I just tried it and it went to Arlo.
A screen shot of the page you get stuck on would help here.
Also keep in mind, CVR requires the cameras to have AC power connected (solar panel charging doesn't provide enough power). Are your cameras powered with an AC adapter?
As mentioned by dcfox1, a screenshot of the subscription flow showing where you begin having the issue would be helpful.
In your second image, you should see selection options for the eligible cameras on your account. If there are no options there, that means there are no eligible cameras.
It looks like the cameras are synced directly to your home network rather than the base station. Your first screenshot shows each camera being Armed on it's own, if they were synced to the base, you wouldn't see them individually in the modes tab. You need to remove the cameras and go through setup again, syncing them to the base station.
One thing to keep in mind is that the camera needs to be on AC power - if it's only on battery, or on a solar panel, CVR won't work.
This is the US support number. If you are in the US, you won't need the 1 (since that is the country code). If you are outside the US, then you should see if there is a support number for your country.
Can you outline what those steps are, and where it goes wrong?
It starts with going into settings, and selecting "Subscription". CVR plan should be in the center of the right pane, with a "subscribe now" button.
After you click that, you'll see the eligible cameras, and choose whether you want 14 days of storage or 30.
Are you getting that far?
Arlo Pro 4
labels
Samsung SmartThings
