Arlo pro4 will not record
Cameras stopped recording. Tried removing one device and now it won't resync
Have you tried the reset procedure? Is the battery charged? If you connect it to AC power will it connect?
bstan1976,
Adding to the troubleshooting steps listed above, also keep in mind Arlo Pro 4 requires an active trial plan or Arlo Secure subscription to save recordings to the cloud. Do you have an active subscription?
Arlo Pro 4
labels
Samsung SmartThings
