Arlo Pro 4 - when connected to Alexa, they all appear to be alerting for all movement, animal, vehicle
All my Arlo Pro 4 cameras are connected to a hub and are set up to notify only on registering person alert ( on Smart notifications ).
Unfortunately when connected to Alexa, they all appear to be alerting for all movement, animal, vehicle etc even though they are turned off in smart alerts. I assumed alexa would only alert for those alerts set to ON in the Smart notifications.
Is this not incorrect?
Flybod,
Arlo Smart notifications take place in the cloud and then are filtered based on your settings when determining whether or not to send a notification to the Arlo Secure app. Alexa will not filter notifications based on your Smart preferences and a notification will be sent from the Alexa device regardless of your Smart settings.
Arlo Pro 4
labels
Samsung SmartThings
