Anyone else getting audio interference that sounds like a rotor? It sounds as though wind is hitting my mic intermittently even though there is no wind, even with audio detection at the lowest setting. Any higher and the noise completely drowns out voices and the sound of tires driving by becomes deafening. Suggestions welcome.
Not actually relevant, as the audio detection threshold does not affect the mic gain.
I'd try removing the camera from the account, and doing the hardware reset. Remove the camera from the shell and press the sync button until the camera flashes amber (about 15 seconds). Then add it back to the account.
Arlo Pro 4
labels
Samsung SmartThings
