I mistakenly named my trusted device (IPhone 11) and now I want to change it. I removed the app and reinstalled and it did nothing, it did not asked me to login with new device. I tried removing again and then shut my IPhone 11 off and restarted and I still can't rename it as it goes right back where I started with the same amoiunt of notifications.
mcarlisle,
You can remove the trusted device by logging in to your Arlo account and navigating to Settings > Profile > Login Settings > Two-Step Verification > Edit > Remove the desired devices.
After you've removed the devices, you can log out and log back in to re-authenticate and rename.
Arlo Pro 4
labels
Samsung SmartThings
