Arlo Pro 4 firmware update
  • 1445 Views
Djns
Hello,
I have 3 same cameras. 1st one connected through hub other two directly to wifi.
One that is connected to hub has this firmware version 1.080.20.1_23_d50a19d,
about which I can't find nothing online?
Hardware version is H4.
Is anyone familiar with above and can shine some light as to why? Thanks.
Also my hub has firmware that doesn't come up
1.21.1.0_1399_9611cf3
Other two have same hardware and firmware versions
1.080.19.2_40_a462be1, HV: VMC4041 PAerH4
You can always check:
https://community.arlo.com/t5/Firmware-Release-Notes/bd-p/arlo-release-notes
What hub? Are you in field trials (sort of a beta for normal users)?
Djns
I was checking firmware in Arlo's pages to see what latest version was, after searching for version I have I came up without results, which prompted me to send a question to Community.
Arlo hub, that you can use to connect cameras to and record locally to a SD card
Click on the link that @jguerdat posted above.
  • 1446 Views
