Arlo Pro 4 cameras 2 way MIC not working
Hi everyone
I have seen similar posts to this many times.
Problem Arlo 4 pros 2 way mic not working.
Currently image is strong sound quality recieved is great, but i cant talk to anyone via the MIC button
So basically the 2 way MIC is one way only
Before you ask Wireless feed is strong.
Also the MIC doesnt work via the PC either
Samsung SmartThings
Please reach out to the Support Team to further investigate this issue you are experiencing. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
Arlo Pro 4
labels
Samsung SmartThings
